honda 250 recon starter issue`s
Old Oct 20, 2010 | 11:41 AM
vtrtodd's Avatar
Default honda 250 recon starter issue`s
i have a 2000 Honda recon 4x2 i have a issue with the electric start it works about half the time i replaced the starter solenoid and check all the grounds and wiring the new solenoid still makes a clicking noise like is is bad but i tested it too and it is good anyone have the same issue or any ideas on how to fix it thanks
Old Oct 20, 2010 | 12:04 PM
bobmc32's Avatar
You said you had checked all the grounds and wiring - have you checked the battery terminals for corrosion?
Old Oct 21, 2010 | 08:46 AM
ddrumman2004's Avatar
How old is the battery?
There could possibly be a bad cell in the battery if old. Battery voltage may show normal volts but drop low enough to not power the starter motor when starter button is pushed.
Batteries can be finicky!
KimSJoh
14
Jul 18, 2015 07:20 PM
Rider252
Jul 6, 2015 03:37 PM
traumajunkie
Jul 5, 2015 03:03 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
