Rear axle boot clamp
Old Oct 21, 2010 | 03:57 AM
09 popo HO's Avatar
Default Rear axle boot clamp
About 3 months back my left rear axle clamp came loose so i had to pull the axle, clean and grease it. Now I noticed that my right rear now has the same problem.
Went to pull the axle and I can't get the bearing carrier off the lower A arm.
Took both bolts out but the bushings seem to be holding it in so tight I can't get her to slide out. I had the same problem last time but was able to get the axle out without removing the carrier.
Any tips on getting the bearing carrier off the A-Arm.
Old Oct 21, 2010 | 04:46 AM
4getful2's Avatar
that's odd, usually the bearing carrier gets seized to the cv joint and not the a-arm bracket. The inner metal sleeve must be rusted to the a-arm. A healthy dose of more pb blaster or whatever penetrating oil that you use, and a couple taps with a hammer and it should fall off
Old Oct 21, 2010 | 12:07 PM
09 popo HO's Avatar
I'm going to try to pry between the lower a-arm and bearing carrier to see if I can relieve some tension and allow the bearing carrier to pull out.
Old Oct 21, 2010 | 12:59 PM
Overdrive's Avatar
You have to pull the steel bushings out of the A-arms before the carrier will come lose.
Old Oct 21, 2010 | 01:47 PM
09 popo HO's Avatar
Overdrive, Thanks for your help. I will try that tonight.
I new someone on the forum would know.
I swear I am going to become an Axle Expert with this machine.
Old Oct 21, 2010 | 03:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yea the steel bushing/spacer is in the carrier about 1/8-1/4" and is why it won't come out. should be good to go after that .
Old Oct 21, 2010 | 07:28 PM
emm54's Avatar
I just changed my axles on my 08 popo 500 and he is right. Those bushings on both sides pull out then the carrier will fall right out. Make sure u use all season grease on the bushings b4 u slide them back thru the lower a arm into the carrier
Old Oct 21, 2010 | 08:12 PM
09 popo HO's Avatar
How did you get the bushings/spacer out. I'm having trouble.
I got the axle out but when i go to put the axle back in it would be easier if I could remove the bearing carrier.
Thanks for all you suggestions. Keep em coming.
Old Oct 23, 2010 | 06:23 AM
UTU's Avatar
UTU
I've used a lag screw,bolts,bent screwdriver tip,etc any thing will work just to wedge in the bolt hole and pull out.
Old Oct 25, 2010 | 01:34 PM
09 popo HO's Avatar
I got them out after about 5 mins of wiggling a socket screwdriver with electrical tape over it for added grip. Once they were out a 1/4 inch I grabed them with some needle nose vice grips.
Got the axle cleaned up and back together and back on the bike.
Went for a long 90 mile ride on Saturday. It held up well.
Thanks for the help guys.
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
bigred20653
Aug 31, 2015 12:41 PM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
