87 honda trx350 fourtrax 4x4
Old Oct 28, 2010 | 07:58 PM
Geo 05's Avatar
Default 87 honda trx350 fourtrax 4x4
Hello i have a 87 honda trx350 fourtrax 4x4 runs great haven't had any trouble with it until recently. The problem i am having is sometimes when i shut it off after riding and start it back up to ride when i put it in gear it stalls it has only did this to me a couple of times but this last time it did this to me it was idling in neutral for about 10 min. went to go and kept stalling everytime i put it in 1st gear left it sit for about half hour ran fine went right into gear and did not stall.Does anyone have any idea what could be causing this to happen? Thank You
Old Oct 30, 2010 | 10:03 AM
hghgrad's Avatar
Feel like you turned the key off when you slide it into gear? Had the same trouble with mine. Turned out to be the neutral switch. I just grounded the switch (lower cover right side, very bottom, 2 8mm bolts holding it on.). I ended up just cutting the wire and putting a ring terminal on the end.
The neutral light is always on, but I'm used to riding sport quads and bikes that don't have a light at all. It also allows you to start the bike in gear.
Old Nov 15, 2010 | 02:54 PM
stewy13's Avatar
where exactly is the switch? i think mine is doing that. got it running after about ten years of sitting and the lights stays on all the time. never did before. now it wont start at all. thinking its a grounding problem. maybe that?
Old Nov 16, 2010 | 03:39 PM
hghgrad's Avatar
If you look at the right side, there's a very small black metal cover. There's only 2 8mm bolts holding it on. It's right around the foot pegs.
wendal
May 9, 2024 09:29 PM
Steeldon
Sep 8, 2015 10:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
blueandy88
Aug 31, 2015 12:42 PM
blueandy88
Aug 30, 2015 08:26 PM
