s.o.s help!
Old Oct 30, 2010 | 01:26 PM
emm54's Avatar
Default s.o.s help!
Sorry to beat a dead horse guys. But I have a 08 polaris sportsman 500 efi. I'm outside attemting to do the 3 way headlight mod with a RELAY and I'm confused about one thing. I found the green wire(low beams) yellow wire(high beams) brown wire(ground) but I only see a red with white stripe wire with the other 3 at the switch right on down inside the pod and a orange with white stripe wire that connects to my power plug(cigarette lighter plug outlet). So which one wire do I use to connect to the relay terminal??
Old Oct 30, 2010 | 03:59 PM
Bowana's Avatar
You need switched power so as long as you use a test light to confirm that they have power when the switch is turned on you can use either. I used the one at the lighter plug and likewise for the ground. I then discovered the wiring under the pod by removing the inspection plate and it may have been easier to hook up there as there is a bit more room but it does not matter.
Let us know if you get it to work.
Hugh
Sep 11, 2000 11:53 AM
