250EX/Recon Clutch slips while cold...?
Old Nov 1, 2010 | 05:05 PM
unclejemima's Avatar
Default 250EX/Recon Clutch slips while cold...?
I had my 2003 250EX out a few times in the last weeks, and I always let it warm up for a few minutes before riding.
After idling for 5 minutes, I'll take it for a drive. If I am WOT (wide open throttle) in a higher gear like 4th or 5th, the engine rpms will climb but the quad does not move faster.
After about 10-15 minutes of driving, this goes away 100%.
Seems straight opposite of what a slipping clutch normally does, I thought they would slip when they got hot. I can ride it for 3 hours straight and it will not slip a tiny bit, JUST when its cold.
Because the 250EX has an auto-clutch, it almost seems like the centrifugal clutch could be the problem, but I really don't know.
Would the clutch adjustment screw at the front help?
Thanks!
Old Nov 2, 2010 | 08:19 AM
EPI Brandon's Avatar
clutch adjustment would be a good thing to check back the screw out til tension than a quarter turn back in. also how cold is it out and what kind of oil are you running in the machine.
Old Nov 2, 2010 | 10:14 AM
Its usually about 75-80degrees or so. Not cold by any means.
I'm running an ATV specific oil (no automotive grade oil)
I'll try the clutch adjustment and see what happens!
Thanks,
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
jbrewster94
Sep 23, 2015 04:16 PM
