500 ho starting/cranking problem.
Old Nov 7, 2010 | 04:08 AM
stcspiderman's Avatar
Default 500 ho starting/cranking problem.
What could be wrong with this? I put a new pull start new starter I started with pull start just fine let it run for a bit I figured I take for test drive got 20yrd just stalled on me.
Would not start.
Now I I got the starter in with the shaft look at videos is the shaft spouse move like it does and the
picture is this a washer or something broke? YouTube - VID 00021 20101106 2219
My other thing my pull start is stuck bind up when I electric starter all it does is click
Is the video should the fly wheel keep turning just goes so far then stops both ways
YouTube - VID 00023 20101106 2226
Old Nov 7, 2010 | 08:35 AM
Steeves's Avatar
It looks like you have a bad starter clutch mech. When you put the starter back on I find it dosn't hurt to put a bit of silicone around the O'Ring on the starter itself. A good Rv silicone. Water is know for getting in the 500 HO pull cord assy. Make sure once you get it back together you check for water constantly. I do this by just pulling out the pull cord and seeing if it is damp. There is a drain at the bottom of the pull cord housing.
Old Nov 7, 2010 | 10:50 AM
t looks like you have a bad starter clutch mech. Where is this at any pics how much do they cost how hard to change thanks
Old Nov 7, 2010 | 02:05 PM
The starter clutch same thing as bendiex. Thing that is brand new why is my flywheel not turning all the way look at the video see what I am talking about
Old Nov 7, 2010 | 07:01 PM
4getful2's Avatar
even with sparkplug out?
Old Nov 8, 2010 | 06:11 AM
Kerbbirds's Avatar
there is supposed to be a washer on the back, but it also looks like part of the old bendix broke it wont go in there all the way, will the motor rotate at all, all i know is that it would take a lot of stress to break the shaft on the bendix, and the only thing that could do that is the motor
Old Nov 8, 2010 | 07:13 AM
Look at the video flywheel will only go so far one way so far the other way.
When I pull start it act like it is stuck won't pull out..
Only thing I could find is flywheel won't make full revelation goes so far locks up why is this.
Old Nov 8, 2010 | 01:17 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Doesn't sound good at all but what do I know? Wonder if you haven't broken off a piece of your piston or a broken rod in there binding up the crank shaft.
Old Nov 8, 2010 | 02:28 PM
how do I know If i broke something or not. as of rod or pistion?
Old Nov 8, 2010 | 03:54 PM
look at the video see what i am talking about. span dex thing that rest on broke
want to know why pull start jams YouTube - VID 00025 20101108 1507
why fly wheel turns so far stops YouTube - VID 00026 20101108 1519
