2003 trail boss 330
Old Nov 9, 2010 | 11:18 PM
2WDTHUG's Avatar
Default 2003 trail boss 330
Hello, I have a 2003 trailboss 330 with a stage 2 dynojet kit and a K&N filter
but I am getting some 25" GBC gator's and I am looking for a bit more low end torque to turn them in deep mud
I was thinking about getting a new sprocket setup and eventually a FMF pipe for it I will have a snorkel on it by spring....
give me some exact part names of what I will need
Old Nov 10, 2010 | 12:18 AM
kevin773's Avatar
Greetings! First, find put how many teeth are on your stock sprockets and then go from there
Old Nov 10, 2010 | 03:27 AM
2WDTHUG's Avatar
Default reply
I think it has 40 teeth stock
Old Nov 10, 2010 | 05:53 AM
ftwflh's Avatar
Get you a Polaris white primary spring and a Aaen blue secondary spring,set the secondary at 2-2.No need to mess with gearing.About all you will get out of a pipe is more noise.For best results call RcR about 330/325 kits he has.
Old Nov 10, 2010 | 08:14 AM
scootergptx's Avatar
Supersock
Hired Gun!
I agree with ftwflh, do what he suggests first. You'll find you're going to get the low end you're looking for. I did put the stage 1 kit on my 325 from RCR and couldn't have been happier. It did come with a pipe, which indeed is a lot louder than stock, but I liked the sound and I think it did add a little extra power. Granted these aren't putting out huge numbers in hp, so the gain was minimal.
Old Nov 10, 2010 | 03:06 PM
2WDTHUG's Avatar
can I get some links on the best place to buy those?
Old Nov 10, 2010 | 05:28 PM
ftwflh's Avatar
Originally Posted by 2wdthug
can i get some links on the best place to buy those?
call rick on the phone 618-644-3211
Old Nov 11, 2010 | 12:17 AM
2WDTHUG's Avatar
will removing my exhaust baffle decrease my torque?
Old Nov 11, 2010 | 05:51 AM
ftwflh's Avatar
Dont mess with your muffler.Doing so will make it sound bad and run worse.Clutching is where your power is.
I ran the EPI pink primary spring and aaen blue secondary on a 330 Trailboss and it ran great.
Polaris white spring does ok too.
Old Nov 12, 2010 | 12:16 AM
2WDTHUG's Avatar
well I am going with the RCR stage 1 kit so i will get the clutching and the exhaust but sadly i won't be able to get my Gators untill spring
Are gators a good choice or do you have any others that work good in snow and mud?
