need some desperate opinions
Old Nov 11, 2010 | 01:40 PM
94bigbear's Avatar
Default need some desperate opinions
popping noise in rearend on a 94 4x4 big bear. does it real bad when turning either left or right. Already replaced swing arm bearings w/ no luck....... Please chim in.....
Old Nov 11, 2010 | 02:11 PM
Jaster94's Avatar
sounds like something inside the differential that is starting to give up & starting to fail! ......uh-oh!. so, it sounds like teeth off of the gears are missing and causing the popping sound? does it lurch/lunge/pop when driving straight? you said "in" the rearend, SO, it sounds gear related unless performance is unaffected. or is the sound around the rearend area?
Old Nov 11, 2010 | 08:50 PM
91Warrior357's Avatar
sounds like something is bad in the differential.
Old Nov 11, 2010 | 11:34 PM
94bigbear's Avatar
It Does it very little when i go straight. But when you cut the wheels hard either way it does it worse and all the time. I can have it in neutral and coast down a hill and it will still do it... Do you think that i am wasting my time replacing the axle bearings? Can i see if somthing is wrong if i take the side cover off the rearend case?
Old Nov 12, 2010 | 12:10 AM
94bigbear's Avatar
if i was to get a new rearend does anyone know what years are compatable w/ my unit?
Old Nov 12, 2010 | 06:25 AM
papa hogg scoot's Avatar
Loved
Community Favorite
I guess i would jack rearend up first and see if up and down motion in rear axle, if so you may get lucky enough to just replaced the bearing and seals,the ring gear is attached to axle and when you turn the axle is flexing or moving enough that it is pulling the ring away from pinion gear if you hadn,t already broken or rounded off the gears , don,t ride atv anymore IMO go ahead an inspect.....
Old Nov 17, 2010 | 04:55 PM
NUTS4STEEL's Avatar
could be the u-joint at he rear of the transmission
Old Nov 19, 2010 | 12:25 AM
94bigbear's Avatar
I thought of this. Maybe the noise is just carrying down the hollow swing arm........ I'll give it a try if the replacement of the axle bearings dont work...
Robinhood
Dec 26, 2015 10:28 AM
rgjackson
Sep 17, 2015 11:21 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
