fourtrax utility questions/help?
Old Nov 11, 2010 | 11:07 PM
kookizuki's Avatar
Default fourtrax utility questions/help?
picked it up for a whopping 50 bucks, runs decent, needed a right front hub/bearing(was ripped off, hence why it was only 50 bucks) got one off ebay for 18 bucks shipped. heres the deal--front plastics are maier aftermarket, no front fenders, plastic is a lighter dull red, seems to fit ok but dosnt line up with the rear at all, anyone have a stock plastic set for this? ill gladly trade!!. how does the headlight come off? sticker says its a removable utility light? it has like 4 ft of wiring attached to it?. i found and removed what appeared to be a rotary **** with a positive and negative wire attached to it, it was tucked up under the front plastic and served no apparent purpose, any ideas? when running the motor makes a rapping/knocking of sorts, but runs smooth, no vibration or anything, almost seems like a normal noise? where the hell is the oil filter and oil drain? the electric starter dosnt work, relay clicks when i hit the switch, even tried jumping a 12v+ wire straight to the starter and nothing, removed the side cover and the starter motor spins by hand fine, but dosnt work when power is applied? overall i love this thing, its fun to ride and slides around better then the suzuki lt230e i have, hoping to get the proper plastics on the front end and fix the little problems and have some fun with it!!
wendal
May 9, 2024 09:29 PM
Johnny Mac
60
Dec 14, 2019 06:13 PM
wendal
Oct 31, 2017 03:31 AM
cboler9
Sep 24, 2015 08:35 PM
wendal
Sep 15, 2015 01:50 PM
