1999 charging issue
Old Nov 12, 2010 | 07:21 AM
bully50's Avatar
Default 1999 charging issue
Hi everyone long no talk, i could use some help once again, my 1999 sp500 seems to be haveing a charging prob, not sure if its my stator or the battery the battery seems to take a charge off a battery charger, but i get half way through a ride and my electric starter wont work and my winch dose not have any pulling power, and at one point wouldn't even pull its self back in, and the awd had no juice to ingage, any hints or thingings i should check would be a huge help thanks guys. also whats the biggest tire i can run with out rubbing with a 2inch left, thanks again.
Old Nov 12, 2010 | 11:37 AM
MECHANIKE's Avatar
use a meter to check and see if you get 14v revved up alittle.if you don't even get 13v,stator,regulator,connection,,,,,,,,,,,,,,,,,th ese batteries offer little reserve imo.
Old Nov 12, 2010 | 04:43 PM
sammydogs64's Avatar
Mine did the same thing it was the rectifier/regulator. Tons of them on EBAY
Old Nov 13, 2010 | 07:45 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Old Nov 13, 2010 | 07:58 AM
Kerbbirds's Avatar
As stated get a multi meter , touch the ends to the battery posts at idle . read the meter then rev it up, should go up to 14 or more volts, usually the regulator, black box in front of the radiator
Old Nov 17, 2010 | 01:13 PM
bully50's Avatar
Thanks for the info guy, the regulator was replaced brand new this year, but i will put a tester on it thanks again.
cody500ho
14
Aug 14, 2015 05:03 PM
Ronbo6270
Aug 6, 2015 11:54 PM
kdg723
Jul 25, 2015 01:20 PM
200es
Jul 19, 2015 04:50 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
