Rancher ES Problems
Old Nov 12, 2010 | 12:22 PM
Frogger1's Avatar
Default Rancher ES Problems
I have a Rancher ES, year model can't remember but it's the first year of the new bodystyle. My problem is the shifter will normally shift thru 5th gear but will not downshift sometimes. I have to turn the key off and I assume reset the computer then downshift to neautral. Doesn't happen all of the time.
I have replaced the reverse sensor due to it not shifting into reverse. (problem solved)
I have been told there are multiple sensors, so where do I start and how can I tell if the sensor is bad.
Oh yeah, when it will not downshift the screen flashes a line -- like this.
Thanks for the help in advance.
Old Nov 12, 2010 | 12:33 PM
budedm's Avatar
I only know what I have read on this forum. Replace the angle sensor.
Old Nov 12, 2010 | 12:36 PM
Frogger1's Avatar
After I posted I read on page 11 I think about a guy with a similar problem. When you posted I was on Bike Bandit trying to locate the part. Do you have any idea of where it's located and how you know if the sensor is bad?
Old Nov 12, 2010 | 12:53 PM
budedm's Avatar
I know it's in the front right bottom of a Recon. Not sure about the Rancher. Go up to the search tab and search for angle sensor. There's about 30 threads about it.
Old Nov 12, 2010 | 01:51 PM
Frogger1's Avatar
Thank you sir!
Old Nov 13, 2010 | 07:27 AM
polymite's Avatar
Go thru all ele. connection and check for water, apply silicon grease to all ele. connections. This takes care of most shifting problems.
Old Nov 13, 2010 | 10:16 AM
TLC's Avatar
TLC
Look through the Search option on this site and add author "HondaMechanic" he explaines all the ES problems well with the help of Pics.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
