Carb to EFI
Old Nov 15, 2010 | 12:08 PM
bjones12's Avatar
Default Carb to EFI
How is everyone? I would like to know if there is away to convert a 2002 Sportsman 700 from a carburetor to the EFI? Any help would be appreciated.
Old Nov 15, 2010 | 12:23 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
As with any project, it could be done. But, it seems like it would be a lot easier to sell the old Sportsman and just buy a new/er one with EFI.
Old Nov 15, 2010 | 12:32 PM
bjones12's Avatar
I would, but I have had this particular Sportsman since I bought it new. I have become to attached...
Old Nov 15, 2010 | 12:43 PM
Supersock
Hired Gun!
Well, any project is possible. You'll need the three basic "T"s.
Time
Tools
The wife not knowing how much it all cost
Old Nov 15, 2010 | 01:31 PM
TLC's Avatar
TLC
You would need to change the wiring get a ECM the buy the throttle body, intakes and injectors, it would be more work and cost than its worth.
I fish with two guys, one has a 700 carb and the other a 700 EFI,there is not much difference between the two other then one needs choke on cold starts. Is pulling a choke worth that much money ,time and labour to you?
I ride both ATVs and can,t tell them apart while riding.
Just the Throttlle body,position sensor and ECU would cost close to a grand. Not Even sure if the 700 EFI uses one or two throttle bodies.
Old Nov 15, 2010 | 02:03 PM
bjones12's Avatar
Thanks for all your answers, I think I will stick to the carb... to much work for no gain
Old Nov 15, 2010 | 06:20 PM
Overdrive's Avatar
You should be very thankful that you have a simple carb instead of EFI.
Old Nov 15, 2010 | 07:39 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
I will not own an EFI model. The carb model is simple and cheap to repair.
Old Nov 16, 2010 | 07:58 AM
TLC's Avatar
TLC
No power gain also, the 700 carb and 700EFI are both rated at 44hp. If you want a cheaper upgrade with noticeable improvement,get a clutch kit or pipe, or 42 TMX CARB or high Duration Cam. or all at once. From here.
http://www.aaenperformance.com/Power700.asp
They have 3 stage kits ranging from $250 to $750. #1 get you 48hp
#2) 50 HP at 6000 RPM and offers superior throttle response in midrange.
#3) 54hp
Old Nov 16, 2010 | 09:06 AM
bjones12's Avatar
Ok, good good. What do y'all think about the rebuild kits on ebay? And what pipe do you recommend?
