winch question
Old Nov 21, 2010 | 09:28 AM
rr-john's Avatar
Default winch question
when i push the button the winch just clicks. i went over everything but still does the same thing any ideas whats wrong ???
Old Nov 21, 2010 | 11:33 AM
randyneff6971's Avatar
I`m guessing you may have a bad relay. try jumping 1 at a time and see if that gets it to run if it does test relay. might need replaced.
Old Nov 21, 2010 | 01:04 PM
james feeney's Avatar
Make sure all your connections are clean and tight. Most likely to be the solenoid depending on which winch. Does it have a can type solenoid or black contactor??
The winch itself shouldn't click, the motor will either turn or it won't.
Hope this helps
JF
Old Nov 21, 2010 | 01:08 PM
Hope this helps
JF
LOL I had my own wires crossed. I meant to say solenoid rather than relay. my bad
Old Nov 21, 2010 | 02:37 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if the connections are good and full battery then the contactor is most likely bad. its not that uncommon and if you do a search you will find alot posts on it.
Old Nov 21, 2010 | 02:59 PM
4getful2's Avatar
maybe it's time to take the winch apart, give it a good cleaning and some lube. they are NOT sealed units
Old Nov 25, 2010 | 03:22 AM
chuck_raduenz's Avatar
take a test light check for ground and power at the winch and work back...
ylomnstr
Sep 22, 2015 12:19 AM
Rick Van Matre
Sep 11, 2015 11:52 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
ylomnstr
Sep 4, 2015 05:02 PM
