02 rubicon transmission
Old Nov 22, 2010 | 10:37 PM
richard r's Avatar
Default 02 rubicon transmission
today i cleaned my carb because i had a issue with it yesterday.after cleaned it started great and runs good now. but when i took it for a ride.i put it in gear and heard a i guess ud say a clickking noise like a gearwas not grabbing but a little gas good to go. so i looked in the oil which i had change 3 day b4 this and it was like a qt over full. and i only put 5.2qts in it. did i put to much ?so i looked and smelled it kida thin.so i changed it but the only thing they had was regular moter oil so i put it in.will this hurt it.i change the oil about every 150 miles i know thats very often.but i use the old in my car that leaks oil...lol..oh after i changed it the noise went away.should i off it or u think its ok just some how gas got init?thanks for ur help.
Old Nov 23, 2010 | 02:57 AM
JRM's Avatar
JRM
others on here say the hondamatic can make a ratcheting sound, thats not good at all- my rubicon has been flawless and the only clicking i have ever herd is my sub-transmission if i rev it up in netural and put it into drive before its back down to idle.
Old Nov 23, 2010 | 09:13 AM
Specta's Avatar
It should hold 5.2 quarts if you removed both drain plugs and changed the filter.
Old Nov 25, 2010 | 04:48 PM
JeffinTD's Avatar
The Rubicon is a dry sump design. To get an accurate oil reading you have to let the quad idle for around 4 or 5 minutes, and sit for two minutes.
If after cleaning the carb you ended up with a higher idle speed that needs to be adjusted.
Lastly, I would for sure run oil rated API SG or better and JASO MA, for motorcycles with a wet clutch design.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
