Glacier Plow ?
Old Nov 24, 2010 | 11:37 AM
ATPmike's Avatar
Default Glacier Plow ?
Hi Guy's. Quick question for you.
I have Glacier Plow that I bought new last year. I used maybe 10 times doing just my driveway. Well I have to say the wear bar on these plows are horrible. Must be very soft metal because it wore down to the plow blade already. My driveway is not that big. Any way's instead of just flipping it I want to replace it.
Will any 50" cutting edge fit?
Thanks
Mike
__________________
Old Nov 24, 2010 | 08:40 PM
switzomatic's Avatar
Polaris makes a heavier duty blade or if you have access to some flat stock you can easily make your own using the old one as a template for drilling the holes.
Old Nov 24, 2010 | 11:10 PM
CaptainQuint's Avatar
Any good steel shop should be able to set you up with a length of stock which has the wear resistance you're looking for. They can also probably cut it to length so all you need to do is drill the holes.
You might want to experiment with different materials besides steel too. High density polyethylene or similar material is used in situations where you don't want to scratch the pavement.
Old Nov 25, 2010 | 03:15 AM
chuck_raduenz's Avatar
go to a steel shop get a 1/4 thick x 3 or 4" high x whatever length. i built my plow and plow about 60 places. in 2 yrs of useing it it wore off 1/4" so far.
Old Nov 25, 2010 | 11:11 AM
ATPmike's Avatar
Thanks guy's
shimanok2
Jan 29, 2016 07:37 PM
kampswas
Sep 23, 2015 05:05 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
