2003 Honda 300EX will not start need help please
Old Nov 25, 2010 | 07:34 PM
bad_azz_banshee01's Avatar
Default 2003 Honda 300EX will not start need help please
I have a 2003 honda 300ex all stock and was riding it and it started losing power and i dont know what happened but it will not start.Ive tore it apart and checked the timing chain and made sure it didnt jump time and every thing was right.Its getting good fire plug is firing bright blue.So i took the carb off and cleaned it and even sprayed ether in carb and it will still not start.I checked the valves and it seemed to be workin fine and valves were workin fine.If anyone could help it would be greatly appreciated thank you.
Old Nov 26, 2010 | 06:09 AM
zooooom's Avatar
Is the cross hatch gone on the cylinder walls?
Old Nov 26, 2010 | 11:16 AM
As in cross hatch what are u referring to not too familiar with 4 strokes have done some engine work on them but not much.
Old Nov 26, 2010 | 01:09 PM
SS420's Avatar
zoooom is referring to the marks that are left on the cylinder walls from when the factory honed them. If they are smooth and have vertical gouges in them you may have and ring issue. Do you have a compression checker? That would rule it out pretty quick. I compression check can tell you alot about your rings, piston and valves.
Did the bike lose power over time (weeks, or hours or were you just driving along and all of a sudden it lost power and died)
Old Nov 26, 2010 | 02:29 PM
The bike belongs to my brother but i was with him while we was riding and it ran good al day and start losing power and all of a sudden quit and hasnt started since.I checked the comprsession and it was great but the rockers had a little wear but i left the tops off where u could see the rockers workin and adjusted the valves by the way they were supposed to be set but i was told possibly could have a valve stuck and might be the reason its not running.
Old Nov 30, 2010 | 08:42 PM
ghostrider450er's Avatar
try poping the clutch to crank it, as in some one pull you off if it manual , if this dont crank it, u need new rings , all engines need is air , fuel, and a tight motor, if its getting gas and fire, the motor isnt tight, ...... i would think..... my 75 cents.
Old Dec 6, 2010 | 04:17 PM
longee13's Avatar
i had same problem do u have a tether cord killswitch check the rubber piece and make sure its on if u do
Old Dec 9, 2010 | 10:47 PM
ba300's Avatar
Orginal Trespassers
do a leak down it will tell you a lot. Did you just pull the valve covers or did you pull the cam cover.
What was the comprsession????
neilbedwell
Nov 10, 2018 11:02 AM
Jake55
Jun 29, 2015 06:43 AM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
lovinhonda
Jan 25, 2000 09:17 PM
