250x rebuild help
Old Nov 29, 2010 | 07:06 PM
Snowman51789's Avatar
Default 250x rebuild help
i am rebuilding an 87 trx250x for a friend. it was smoking all the time not just on start up. so i took it apart and the piston looks good so i am just goin to throw in a set of rings and hope that takes care of it. however it it not the stock bore. the piston measures 3.148" about 80mm. i have looked all over online and i can not find replacement rings for it all i can find is the entire kit. anybody have any advice were to look?
thanks
David
Old Nov 29, 2010 | 07:14 PM
also dose anybody know were i can get the valve cover gasket? i cant seem to find it on my local dealers online micro fich
Old Nov 30, 2010 | 07:30 AM
trx300man's Avatar
For the gasket just go to ebay and buy a top end gasket kit. probably less than just one gasket from Honda.
Old Nov 30, 2010 | 07:33 AM
budedm's Avatar
Old Nov 30, 2010 | 10:37 AM
budedm's Avatar
Also, the 300EX has the same bore size as the 250X, so maybe the rings are interchangeable. I am not sure about this though. The ring sets have different part numbers, but that doesn't necessarily mean they are different.
Old Nov 30, 2010 | 05:23 PM
the piston is not the stock size. i belive it has a 288cc big bore kit. the bore is 80mm so stock rings wont work as far as i know
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
