100 octane
Old Nov 30, 2010 | 02:31 PM
cody450r's Avatar
Default 100 octane
has any one had any experience with using this gas? if so could you tell any difference in the performance?
Old Nov 30, 2010 | 03:38 PM
Doctorturbo's Avatar
GOT BOOST!
Unless you have a higher compression piston there is no reason to use a higher octane fuel. Use what the OEM says to use.
Old Dec 1, 2010 | 07:44 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
I 2nd that.
Old Dec 2, 2010 | 09:32 PM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
$7.50/gallon never smelled so good! But that's about all you will get unless you're tuned for it.
I usually run a half tank of it in my quad and street bike at the beginning of each riding season. I feel it helps clean out the fuel system. Especially with both of them being carb'd.
Old Dec 3, 2010 | 07:33 AM
ddrumman2004's Avatar
100 octane gasoline burns slower. Like Docturbo said, unless you have a high compression piston etc....no need for it.
I run 97 octane fuel in my 97 Ford truck because it pings like heck on 87 octane. Always has since I bought it.
Save the extra money and instead purchase some Seafoam to run through the fuel system to help keep it clean.
Old Dec 3, 2010 | 03:52 PM
Koopa's Avatar
Originally Posted by ATVrider89
Iusually run a half tank of it in my quad and street bike at the beginning of each riding season. I feel it helps clean out the fuel system.
? How so? Not that I'm arguing or anything just didn't think Octane was a detergent or cleaning substance.
Old Dec 3, 2010 | 05:34 PM
GOT BOOST!
The race gas'es have a higher order of hydrocarbons and are "cleaner". I use to do the same thing.
Take a cup of regular gasoline and let it evap over time. See all the varnish at the bottom of the jar. Now do it with race gas. There will be nothing or next to nothing in the bottom of the jar.
I agree with the smell. Not much that smells better than burned TRICK coming out of the pipe of a well tuned engine!!!
Hmmmmmmmmmmm maybe that's my problem???
Old Dec 3, 2010 | 07:35 PM
ATVrider89's Avatar
In my opinion, (keep in mind it's an opinion) turbo blue, is equivalent to just about any octane booster or fuel system cleaner that you will buy at a dealership or on a shelf (some are cheap, some cost up to $20+/ per bottle).
I am not sure how it works with modern fuel injected engines which are mostly now designed to run on regular 87, but my carb'd motors love it.
Just remember, do not run it in anything with catalytic converters! So don't put it in your car!
Polaris-400
Aug 19, 2015 02:20 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
ranvette
Jun 10, 2015 09:57 PM
Tree Farmer
May 6, 2000 03:36 AM
