1998 Foreman 450 S Racing on Startup...
Old Nov 30, 2010 | 03:01 PM
bluduk15's Avatar
Default 1998 Foreman 450 S Racing on Startup...
It starts fine, but it races for a few minutes enough so that I have to put the brakes on to kick it into gear.
After it warms up, it runs okay, but will stall if I stop.
Is this just a dirty carb? Is this easy to clean?
Any help would be appreciated.
Thanks
Old Nov 30, 2010 | 08:06 PM
ghostrider450er's Avatar
Thanks
clean the carb look for the brass fittings in it with tiny holes in them , like a water sprinkler , these are jets, remove with flathead screwdriver and clean good, do not gouge the holes any bigger cause it will mess them up, just clean and put back together and ajust the air mixture screw all the way in and come back out 2 and 1/2 turns and crank it then fine tune the air mixture screw to how high or low u want it to run...... if this dont stop it check the valves have them adjusted ( $25-$40) as this will affect idle problems but cleaning the carb will def not hurt the ol machine..... my 75 cents
Old Nov 30, 2010 | 08:54 PM
bluduk15's Avatar
Thanks, that sounds like a plan. I don't have time right now, is there a "Seafoam" type of cleaner that I could just run through for now?
Old Nov 30, 2010 | 09:23 PM
i wouldnt recomend putting anything in the engine if it has a lil age on it, but the carb clean should take an hour maybe 2, that carb is pretty simple might only take 30 minutes,mainly just clean the jets as i described earlier, that way it wont be too time consuming.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
