06 450 er wont idle......
Old Dec 1, 2010 | 08:26 PM
ghostrider450er's Avatar
Default 06 450 er wont idle......
ok got a 06 450 er, stock ..... it wont idle and its hard to crank, so i took the carb off and cleaned all the jets, but the smallest wouldnt come out.... or does it...??? but i cleaned it in the carb and sprayed cleaner up in it and it had a real good stream come out, so i put it all back together and it cranks way better but will only run on choke or if u throttle it......... why wont it idle by itself it runs great under throttle ...... what could this be ...... ???
Old Dec 2, 2010 | 07:56 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
My money is there is still some trash in the carb. It's not uncommon to have to go through it a couple of times. I know I seem to have to. The slow jet should come out. If it don't be very, very, careful. Don't force it. Maybe let it soak for a while before trying to clean it. We've used torch tip cleaners to clean the small holes.
ss97
Jun 14, 2008 10:35 PM
Drockstar
Jul 7, 2006 12:11 AM
