Rubbing Chain
Old Dec 2, 2010 | 01:30 PM
MattyB's Avatar
Default Rubbing Chain
I have an '86 Fourtrax 70 that the chain is rubbing on the chainguard. It has a ton of play in it but not enough to take out a link. Should I just get a new chain for it?
Thanks
Old Dec 2, 2010 | 01:55 PM
budedm's Avatar
One way to tell if it's worn out is to pull it away from the rear sprocket in the back. If you can see more than 1/3 of a tooth, it is worn out.
A second way is to lay the chain on the floor in as straight of a line as possible. Pull & push the chain together and apart. If it moves more than about 3/4", it is worn out.
A third way is to hold the chain up and measure the distance between 10 links. The distance that it should be if it is good should be listed in a chain chart on the web somewhere. Or just a place that sells chain can tell you.
But, beware that if the chain is worn out, so are the sprockets and they should also be replaced.
Old Dec 2, 2010 | 06:12 PM
Leroy400ex's Avatar
so is there any way to adjust the chain? if its fully adjusted and its still loose, you should be able to take a link out of the chain. in theory...
Old Dec 3, 2010 | 07:41 AM
ddrumman2004's Avatar
Not familiar with this atv but can you adjust the chain to where it's completely loose? Run the adjustment all the way "forward" to put max slack in the chain?
Then you could see if a link can be removed. Other than that, new chain as well as new sprockets.
Old Dec 6, 2010 | 11:42 AM
MattyB's Avatar
Thanks for the replies. After looking a little closer I realized that the chain is rubbing on the chain tensioner. I think this tensioner should have rubber around the bearing. I guess the rubber has worn off of the bearing. Has anyone had any experience with this?
Thanks
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
