08 sportsman 800 starting issue
Old Dec 14, 2010 | 10:52 PM
badazzpred's Avatar
Default 08 sportsman 800 starting issue
Im trying to troubleshoot my starting problem?? the best way to explain it is when the machine is in park and I go to turn the key which I only turn it to the on position first to let the fuel pump cycle and then turn it to the full start postion it cranks over once but doesnt start then kills Then I turn the key back off do the same thing again and it starts right up what could be the problem???? Thanks
Old Dec 15, 2010 | 03:32 PM
badazzpred's Avatar
Any suggestions please.............
Old Dec 15, 2010 | 04:06 PM
Kerbbirds's Avatar
Fuel pump getting weak?
Old Jan 22, 2011 | 12:00 AM
badazzpred's Avatar
I think either the battery is going or there may be a flat spot on the starter....
Old Jan 22, 2011 | 05:47 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check the battery voltage before and while trying to start it to see if it drops down alot. this would tell you if the battery is getting week. imo
Old Jan 22, 2011 | 08:55 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Fuel not getting through the filter the first time? Or at least not enough.
How does it run once it started?
......Caper..........
Old Jan 22, 2011 | 09:59 AM
badazzpred's Avatar
Once its started it runs great....................and just curious where is the fuel filter and can it be changed like for maintenence?
Thanks
Old Jan 22, 2011 | 03:59 PM
Not sure on the 800 models ....The EFI models should be inside the tank at the pick-up I think..........They may have one in-line also and just a screen in the tank, I am sure someone with a 800 will chime in and answer your question.......Caper......
Old Jan 22, 2011 | 06:03 PM
Kerbbirds's Avatar
under the box in the front , inline filter, if battery is getting weak it can cause the starter not to engage every time
Old Jan 23, 2011 | 06:50 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check the voltage?
