450r shocks on 400ex??
Old Dec 18, 2010 | 06:55 PM
daves97's Avatar
Default 450r shocks on 400ex??
Hello this is my first post on here. I bought a honda 2005 400ex a couple of weeks ago and I just put some 450r shocks on the front. What kind of adjustments will I have to make or will they be ready to roll?? Also will 450r rear shocks fit on the 400ex? Thanks
Old Dec 19, 2010 | 04:31 PM
daves97's Avatar
45 veiws and no help????
Old Dec 20, 2010 | 12:19 AM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
I am not speaking from experience here but I always thought that the 450R had bigger shocks than the 400ex therefore causing the front end to sit up higher?
Old Dec 20, 2010 | 01:23 AM
daves97's Avatar
It did feel a bit higher. I had been riding all day in the desert and when I got home I put them on and only rode around my hood but it felt higher. can I adjust them down a bit?
Old Dec 20, 2010 | 09:08 AM
ATVrider89's Avatar
You can probably adjust them a little bit (harder/softer) but I am not sure how much that will help you out height wise. Once you put on the rear shock it should even out.
Did the shocks bolt right up or was there modification required? I was going to put 450r shocks on my trx250r a couple years back but after looking into it it seemed like too much of a hassle (front end would be too high).
Also, welcome to the forums!
Old Dec 20, 2010 | 12:35 PM
daves97's Avatar
there was a bit of grinding on the shock and the frame but nothing major.
Old Dec 20, 2010 | 05:20 PM
Mahones781's Avatar
get extenede a arms and u should be alset if its to high for you, my buddy just did the same thing. hasnt had any probelms wit his factory a arms and its ridin great, and yes the rear shock fits also. he did have the lowerin kit on the back shock tho. idk if it made a difference in the fit.
Old Dec 20, 2010 | 10:03 PM
daves97's Avatar
thanks
Old Dec 20, 2010 | 11:59 PM
maclizzler's Avatar
Default 450R probs
The front shocks fit perfectly no machining necesarry however, it does increase the ride height a bit on the 400. The rear shocks will not fit though. I rode my buddies after we put on the 450's, and the ride did not seem all that improved. It soaked up woops a bit better--- a bit, but not much. It would probably be best to go ahead and dig in your pockets and grab some elkas.. 900 or so for the front shocks without resevoirs.. The difference with those bad boys is completely noticeable..
2008 400 EX
HMF full system
K&N intake
K&N power lid
ITP sand starts
douglas wheels
spyder grips
asv levers
asv lines
M/M decals
Old Dec 26, 2010 | 04:35 PM
daves97's Avatar
well the shocks were a big improvement! I only got to ride about 15 minutes before i took a spill and broke my shoulder blade so I'll have to wait about 4 to 6 weeks to try them out again lol.
