1986 lt 230 quadsport rear end adjustment
Old Dec 28, 2010 | 07:34 PM
miller6951's Avatar
Default 1986 lt 230 quadsport rear end adjustment
Hi i have a 1986 lt 230 quadsport and When i adjust the chain I tighten the clamps down as far as they go. But the chain still loosens after a ride or two. This quad has new rear bearing new swing arm bearings new rear sprocket so it cant be any of those. Any suggestions
Old Jan 2, 2011 | 01:39 PM
ktmbk's Avatar
is it that the adjuster loosens up and slips? or are the chain and sprokets worn out?
Old Jan 2, 2011 | 04:24 PM
snow racer's Avatar
Get a good o ring or x ring chain. Is it a stock chain?
Old Jul 5, 2011 | 02:41 PM
McFarling's Avatar
Default What brand chain did you get?
Did you get a low quality chain?
IF so it might be stretching every time you ride it.
Or if you are tightening the chain too much when you land off a jump or bump the chain gets stretched.
Remember to look at the chain adjustment with nobody on the quad, then get someone on it so compress the suspension to the full bottom and make sure it's not too tight at that point. If it it when you land the chain gets stretched at this point and can actually break.
STLyamwar
Jul 25, 2020 04:44 AM
Backwoods_badass
Aug 2, 2015 10:40 PM
NatePerz
Jul 27, 2015 03:27 AM
JoAnnS
Jul 23, 2015 02:18 PM
rcappie4
Jul 10, 2015 04:54 PM
