Honda Recon Starter Issues
Old Dec 29, 2010 | 08:07 PM
hamsfarm's Avatar
Default Honda Recon Starter Issues
I have a 2005 Honda Recon Es and am having starter problems. When you hit the stater button all you hear is clicks. Oftentimes you can tap on the starter to get it to turnover.
Old Dec 30, 2010 | 08:17 AM
ddrumman2004's Avatar
If tapping on the starter motor itself gets it started, it's time for a new or refurbished starter motor.
Old Dec 31, 2010 | 07:13 AM
papa hogg scoot's Avatar
Loved
Community Favorite
If you can lightly tapp starter IMO an starter brush is sticking or wore down and the viberation of the tap relocate brush in holder to help make contact to armature.So you may try to re brush starter with brush plate[BRUSH KIT] will have them in it.
Old Feb 2, 2020 | 10:35 PM
hrcanet's Avatar
Rebuilt starter on 05 Honda recon es and it still won't kick over.starter relay was clicking but now it's buzzing.need help.do I need a new starter or relay
Old Feb 3, 2020 | 03:00 AM
A buzzing solenoid is usually a flat battery. It can also be a seized engine or starter motor, or the thick wires not being tight enough (including earths). So, check the connections for corrosion and looseness, charge the battery and, if possible, check it is good. Check you can turn the engine over via the pull start. If all else is OK, remove the new starter and check it for being OK, shorting the live side to earth can also make the solenoid buzz. Please, all of you, ignore the "tap the starter if it doesn't work" advice. On many Recon, and all 420s the magnets are inclined to drop off the case, hitting the case encourages this no end. I have a box of about six 420 motors, all with loose magnets.
Sirreal
Feb 5, 2007 01:18 PM
slimshady75
Jul 11, 2004 07:01 PM
VEGAS650
Apr 3, 2004 12:47 AM
rudyraptor
Jan 10, 2004 09:31 AM
RacinJason
Jan 15, 2003 09:37 PM
