Sportsman Exhaust
Old Jan 13, 2011 | 07:41 PM
sudsy's Avatar
Default Sportsman Exhaust
Has any one used HFP Exhaust system on your sportsman? I have an 04 700 EFI any recomendations? And did you need an controler for your efi? just wondering
Old Jan 13, 2011 | 10:19 PM
switzomatic's Avatar
Did you mean HSP? If so, they are awesome sounding. Had the true duals on my 09 800. Shouldn't need a controller or remapping. Ran that exhaust and a single aaen pipe prior to that with no issues.
Old Jan 14, 2011 | 12:23 AM
Ghost Rider 11's Avatar
If you change the exhaust you will need an efi tuner, otherwise you will be running lean and you won`t get the full power gain from the exhaust.
Old Jan 14, 2011 | 03:08 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I put an HSP on my 500 EFI and it sounds great. Gave me a little more low end thru mid range power and speedwerx claims it was not necessary to add a fuel controller since the EFI would compensate for it. I added one anyways and pipe with controller there's a noticeable difference!
Old Jan 14, 2011 | 05:21 AM
sudsy's Avatar
Thank You I did mean Hsp. Ok so look like a controller any one in general I should use? do they just plug and play or do I have to tune it in with a computer
Old Jan 14, 2011 | 05:29 PM
Kerbbirds's Avatar
power commander makes a really good product and hsp will prolly tell u the same thing, they are a plug and play set up in a way, but if u want the best results you can put ur quad on a dyno and make ur own fuel mapping.
Old Jan 14, 2011 | 05:37 PM
sudsy's Avatar
Thank you
Old Jan 14, 2011 | 07:08 PM
From what ive read, the efi computer does not have the ability to compensate for engine mods, that`s why a tuner is needed. If the computer had an 02 sensor hooked up to it so it could read the air fuel ratio in the exhaust the computer would be able to compensate to a certain point for added engine mods, but our atv`s don`t use an 02 sensor. Maybe that will come in the next generation of ATV`s
Old Jan 15, 2011 | 09:18 AM
sudsy's Avatar
Thank you much for all the input. I purchased a full HSP system couldnt pass up the price. They claim I dont need a controller but I'm going to put one on anyway.
Old Jan 15, 2011 | 09:45 AM
You won't go wrong with adding the controller. It will make the most of your bikes potential with the exhaust. Don't forget a quality intake as well. With the exhaust and controller that baby's gonna want to breath.
Cole Hadden
Jun 15, 2025 09:05 AM
traumajunkie
Jul 23, 2015 02:10 AM
bpegram84
Jul 22, 2015 08:15 AM
HondaR24
Jul 21, 2015 12:12 PM
cSchwartz
Jul 12, 2015 07:42 PM
