300EX Not running right
Old Jan 19, 2011 | 04:16 PM
khuelsk2's Avatar
Default 300EX Not running right
I have a 2002 300EX that has been bored out to a 330cc. It starts up and idles great, but when you get in the higher rpms it cuts out. I didn't know if this would be a timing issue, a valve issue, or possibly just needing to run a high octance fuel. Any help would be greatly appreicated.
Thanks.
Old Jan 19, 2011 | 04:37 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
High octane fuel would only be needed if the compression has been bumped up with the big bore. That is a possibility.
Also you will want to check the jetting. The main jet (top end jet) may be too big if it bogs down at full throttle.
Do you know how to do a plug chop?
Old Jan 19, 2011 | 04:52 PM
khuelsk2's Avatar
I believe it is running a bit higher compression. It used to run just fine in the same setup about a year ago. I have no idea what a plug chop it though. I just though that something such as the valve or anything had become unadjusted and would cause this.
fullprice54
Jun 18, 2015 09:44 AM
NONEtooSMART
Jun 17, 2015 08:48 AM
Hondaislife
May 28, 2015 01:43 PM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
blazer316
Feb 27, 2001 01:28 PM
