scrambler 500 4x4 problems help
Old Jan 21, 2011 | 01:06 PM
quadqrazy's Avatar
Default scrambler 500 4x4 problems help
Just bought a 2000 scrambler 500 4x4 it has a fmf pipe and was told a clutch kit seems to have some problems any help with ideas what the problems could be 1. it sputters and runs rough in reverse unless I hold the override button 2. while doing some donuts in snow in 2wd it made a loud pop and seemed to engage awd with the switch still on 2wd 3. it seems to run better with the choke on all the time 4. leaks gas out the overflow of the carb only if its not running im new to polaris and have no idea where to start on fixing these problems thanks
Old Jan 21, 2011 | 05:42 PM
ftwflh's Avatar
The reverse and override are the way it works.You can unhook it but I wouldnt until you are you are more comfortable with it.The pop was the 4x4 trying to kick in(it is not a good Idea to be cutting doughnuts)
You need to remove the carb and clean the jets.
Old Jan 21, 2011 | 06:22 PM
quadqrazy's Avatar
thanks for the info I will try cleaning out the carb
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
