Grizzly belt drive
Old Jan 23, 2011 | 01:39 PM
john clendenin's Avatar
Default Grizzly belt drive
Is there a way to protect the belt drive because mine has slipped and started smoking several times recently going through a creek on the farm.
Old Jan 26, 2011 | 03:05 PM
fordrulz's Avatar
sounds like it got wet??? how many miles you got maybe the belt it excessivly worn. i put a clutch kit in mine and made a huge difference.
Old Jan 26, 2011 | 03:20 PM
DODGE57HEMI's Avatar
Mopar Man!
How big of tire are you running on it?
Old Feb 8, 2011 | 03:38 PM
Troyboy68's Avatar
Ya i actually smelled some rubber burning on mine too(09 Grizz 700) i had it pegged up hill in about 6 inches of snow,im running 26 big horns org, 9 wide in front and 12s in back,,even the guy behind me smelled it too,hmmm.
Old Feb 8, 2011 | 04:36 PM
Mopar Man!
Something is not right. Grizz's have one of the best tranny's in the industry and should be able to push 27 without issue. I know tones of guys doing it without any problems. If you want more info on it that guys might have a better answer for you! My 09 has been running flawlessly now for almost 2000 miles.
Grizzly Riders - Yamaha Grizzly ATV Forum
Old Feb 8, 2011 | 07:26 PM
geoman's Avatar
You probably got some snow in the belt housing, if the belt gets wet it will slip and burn it. The grizzly has a pretty good spot for the intake side of the belt drive, you may chack for any cracks or holes in the casing or the intake itself.
Old Feb 9, 2011 | 03:57 AM
Troyboy68's Avatar
Thanks,ya it only happen that one time,if it happens agian i'll bring it to a shop and have it checked out.
Old Feb 15, 2011 | 11:49 PM
PAGrizz550's Avatar
X2 on the belt getting wet or snow being sucked in through the cvt intake. If your really worried or it keeps happening pull the belt cover and have a look at it,you can also measure belt width and check the cover gasket for damage/leaks. Theres alot of how to on you tube and some other grizzly forums.
Old Feb 16, 2011 | 03:44 AM
Troyboy68's Avatar
Thanks PAGrizz550,ya it only happened once(so far),,,
Cummins Driver
Sep 11, 2019 01:22 PM
merryman
Sep 6, 2015 10:20 AM
toonces
Jul 31, 2015 09:27 AM
Jul 28, 2015 12:12 PM
trouttracker
Jul 20, 2015 11:54 AM
