99 Foreman 450 ES, no spark, won't shift
Old Jan 29, 2011 | 08:41 PM
myersti2's Avatar
Default 99 Foreman 450 ES, no spark, won't shift
Hi, I have a 99 Honda Foreman 450 ES. The battery was dead last weekend so I pull started it. I let it idle for a minute and then started to rev the engine fast to try to get it to warm up (20 degrees outside) and it revved and stalled out. Tried to pull start it again and nothing. Began working on it this weekend and tried to check the spark with both a spark tester and by putting the spark plug on the cylinder (new plug, new fully charged battery), no spark. I then tried to shift the unit out of N and the shifter doesn't work either. Any ideas?
Old Mar 3, 2011 | 04:29 PM
wvgoofy's Avatar
check fuse beside batt
Old Mar 5, 2011 | 08:39 AM
zitaron's Avatar
is the battery good
is the regulator putting out a charge - most likely regulator ( has anyone else got one near you, to change over and try)
but check battery first
Old Mar 5, 2011 | 09:06 AM
snow racer's Avatar
Does it crank? The kill swich might not be in the run possition.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
Jul 22, 2015 05:00 AM
