which suspension is best for the 400ex
Have you done a search under some of the other headings for suspension? There have been quite a few discussions on this subject. I think that no matter how much research you do, you will NOT find the perfect setup on the first try!
You will probably have to plan on buying a set, and modify them after you use them for a while.
Good luck. TCS and AXIS seem to be the hot topic around here.
You will probably have to plan on buying a set, and modify them after you use them for a while.Good luck. TCS and AXIS seem to be the hot topic around here.
Works are the best for the money, AXIS is a division of Penske which builds world class suspension for Formula1, CART, and other road racing cars but they are double the price and hard to get. Resivours are great and adjustable compression.
