96 honda 300ex help
Old Jan 31, 2011 | 05:05 PM
blacklabel21's Avatar
Default 96 honda 300ex help
I have a 1996 honda 300ex.The problem i am having is it wont fire and when it does it it doesnt last to long.I put a new plug in and check to make sure i had spark which i did.gasonline is good.The way i have to get it started is to choke it and hold the trottle for a few second then let off then it might start.I just had the carb jetted two years ago.I just cant figure out why it wont stay running after i get it started even when i have the choke on and hitting the trottle to.PLus i live in ohio and its cold but last year it started up when it was -5 out.I even had the battery charger to start it preaty much it.I did all the easy fixes first.Now i need you guys to help me on this problem.
Old Jan 31, 2011 | 05:45 PM
sdm111's Avatar
2 strokes or 4
Sounds like the carb. needs cleaning
Old Feb 4, 2011 | 02:59 PM
ohiowoodsrider250r's Avatar
i'm going to have to cosign the above post on this..you might want to clean the tank and fuel lines at the same time. otherwise it might be a useless effort, i once had fuel free flowing out my float vent hose. once cleaned no more fuel flow out of the vent..but it didn't start...so i cleaned it 3 more times and thought whatever is going on here is obviously over my head. so i took it to a shop. they cleaned the fuel tank. 45.00 dollars wasted. and it certainly seems to be a case with you're 300ex to. well good luck
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Wiley wolf
Sep 7, 2015 08:32 PM
Jason Campbell
Sep 7, 2015 02:25 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
