Rincon spark plug question
Old Feb 9, 2011 | 09:29 AM
ccbracing's Avatar
Default Rincon spark plug question
Bought an '05 Rincon a few months ago with about 100 miles on it. Wouldn't start the other day. Pulled the plug and the center electrode looked like a pencil point. Is this a concern? Wondered if it is running too hot and might damage the cylinder. thanks!
Old Feb 9, 2011 | 11:00 AM
Doctorturbo's Avatar
GOT BOOST!
I don't know what you mean by pencil point but if the center electrode is very small and to a point it more than likely has a platinum plug in it.
I would go back to a standard NGK plug if it was mine.
Old Feb 9, 2011 | 12:45 PM
ccbracing's Avatar
It is the standard plug. The picture in the manual shows a flat center electrode, and if rounded, it should be replaced. Mine looks like it has gone beyond rounded and has a point. Didn't check to see if it was sparking. Assumed it wasn't as I sprayed starter fluid in the carb and it fired once but that was it.
Old Feb 9, 2011 | 05:39 PM
GOT BOOST!
Got ya. Yes, if the plug is like that and the center electrode is rounded, it needs to be replaced.
Old Feb 9, 2011 | 08:54 PM
steiner's Avatar
what's wrong with putting a different kinda plug in , just wondering , I mean if like the platinum ,are they bad or some thing ,I don't know
Old Feb 10, 2011 | 12:49 AM
GOT BOOST!
Nothing really wrong with them. It's just the plats can't handle the fowling like a regular plug can. The regular plugs are much more forgiving.
Old Feb 10, 2011 | 09:55 PM
steiner's Avatar
what about the erritioum plug,I know it's not spelled right lol!!!!!
Old Feb 10, 2011 | 11:31 PM
GOT BOOST!
LOL, that would be iridium plugs. Iridium plugs last a long time because they are hard and the metal does not wear away as fast as regular sparkplugs.
Do they make more power? No
Are they worth it? IMHO no.
Old Feb 12, 2011 | 09:17 PM
steiner's Avatar
thanks
Old Feb 12, 2011 | 10:21 PM
Specta's Avatar
Less voltage is required to jump between two sharp points than it does to jump between two round points which leaves more voltage to "flow" across the gap which in turn ignites more fuel.
An iridium tip spark plug will deliver a "crisper" spark for a longer period of time than conventional spark plug will because the center electrode retains a "point" far longer than the softer metals of lesser spark plugs.
You will need to replace “regular” spark plugs several times to retain the performance over time as one iridium tip plug will deliver.
