truck tire psi question
Got new tires this fall Coopers, on the side says 80psi, but no other psi.I haul lumber and tools around but not a thousand lbs. at a time . I try to get 2 winters out of a set of overpriced rubber, dont want to wear down the center by running 80 if I shouldn't. So tonight I put 45psi in till I hear yalls opinions. Cooper Discoverer load range"E"
Thanks in advance. Matt
Not that this is the right section for this but I run 65 in winter and 80 in spring through fall. You'll get better gas mileage running proper psi. and you can actually wear a tire faster under inflated.
With truck tires I experiment until I find the optimum pressure. I paint or tire chalk a wide stripe across the tread and drive it around for a bit with the same load I'd normally have. I adjust the air pressure up or down until I get a consistent wear patch on the stripe. You can do the same thing for various loads you may tow or carry so you know how to adjust the tire pressure for the given load.
It takes some time but the tires wear more evenly once you get the pressure optimized for the load you carry.
look on the door jam of the truck or the owners manaul and you always go by what the vechicle recommends and not what is on the tire. w/ that high or pressure it must be a high load range tire(alot of ply tire say,10 or better).
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Resident Killer!
Very good idea.
The reason you go with the truck's listed pressure is they are balancing the weight of the truck with fuel and passengers, the handling, and the overall economy. You can have two completely different trucks riding on the same tire. What is good for a GMC Sierra 2500 is going to be overinflated for a Toyota Tacoma or Nissan Frontier.
Worked tire installation for several years. Hope all the information helps.
