400ex problems
Old Feb 10, 2011 | 12:57 PM
LJ_in_Fl's Avatar
Exclamation 400ex problems
Hi I have a 00 400ex that only runs while on choke & at high rpm's . It will ride around perfect at higher rpm's but when allowed to drop a little it begins to backfire then shuts off when allowed to drop lower on the rpms. Also I go threw plugs like crazy. Any help will be greatly appreciated.
Thank you
Old Feb 10, 2011 | 01:50 PM
Doctorturbo's Avatar
GOT BOOST!
You have a plugged up pilot jet. Take the carb apart and give it a good cleaning. Make sure you REALLY clean the pilot and main jet.
Old Feb 10, 2011 | 02:05 PM
LJ_in_Fl's Avatar
ok I will try that. does that have to do with the plugs fouling to?
Thank you btw
Old Feb 10, 2011 | 02:48 PM
GOT BOOST!
If the plug is fuel fowled it can if you run it on the choke a lot. If it's oil fowled, then no.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
