carb trouble 110atc
Old Feb 10, 2011 | 04:45 PM
Pharmerphil's Avatar
Default carb trouble 110atc
I've been working on a 110 atc, I can get it to start up and idle great, but it dogs out when getting on the throttle. I've had the carb apart and cleaned and inspected it, looks good. My manual says when setting the pilot screw to turn it in till it starts to stall and then turn it out till it starts to stall and then split the difference. (I have tried the all the way in and then back out 1 1/2 turns too). My problem seems to be that i can turn the pilot screw in and out and it doesn't change the motor at all. Do i need a new carb/jet kit or am i missing something? Any help would be greatly appreciated.
Old Feb 10, 2011 | 06:17 PM
sdm111's Avatar
2 strokes or 4
Sounds like the carb. is still gummed or dirty. Does it run better on choke? Does it have a new spark plug?
Old Feb 10, 2011 | 10:08 PM
steiner's Avatar
ya or you bent one of the jets man
Old Feb 11, 2011 | 02:00 PM
yeah it does respond to throttling up better when choked, brand new plug gapped to .026
Old Feb 11, 2011 | 02:43 PM
sdm111's Avatar
2 strokes or 4
Impossible
Old Feb 11, 2011 | 02:46 PM
sdm111's Avatar
2 strokes or 4
Take the carb. apart jets, float, needle valve and clean everything real good. Pay particular attention to the pilot jet and the passages in the carb's throat. Run a piece of fine wire through all the jet holes and passages.
Old Feb 11, 2011 | 02:58 PM
I took the carb back apart and was cleaning things again, the smaller brass screw deal next to main jet holder, underneath the float, doesn't seem to have clear passage all the way through, I dont know if this is the way it is supposed to be or not, It seems to be at the other end of the portal that the pilot screw threads into and thus makes me wonder if this is my problem. there are holes at each end and going seemingly to go through the length of the deal but when i gently push a small needle through, it stops a little way from each end. the one end has the slot for a flat screwdriver and the other end has about 8 horizontal holes that are all clear and connect to hole at the end that end of the deal. any thoughts? the fine tip at the end of the pilot screw still looks good.
Old Feb 12, 2011 | 06:26 AM
sdm111's Avatar
2 strokes or 4
That's the pilot jet is has the holes down the sides of it and has a hole through the length that needs to be clear, so to answer your question yes it's suppose to be clear all the way through to pickup fuel from the bowl if not it will do what you are describing. A needle won't fit it has to be a piece if wire. If you can't clear it just go get a new jet from the dealership for 5 bucks.
Old Feb 12, 2011 | 08:01 AM
thanks for all the help, hopefully that will do the trick, i didnt want to go trying to clear it too hard until i knew for sure it was supposed to be clear.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
