1985 atc 125M help!!!!!
Old Feb 13, 2011 | 10:30 PM
sclark's Avatar
Default 1985 atc 125M help!!!!!
hello
i just got a 1985 atc 125m it wont run. i clean the carb all the jets,filter,etc i have spark. i cant check compression cuase you need the engine warm up at operating temp before you can check compression, it seems to have some cuase if i can the intake off and place my had over it i can feel a sucking. all i know my arm is getting tried of pulling!!!! lol
any ideas?
Old Feb 13, 2011 | 11:35 PM
Doctorturbo's Avatar
GOT BOOST!
Originally Posted by sclark
hello
any ideas?
Do the compression anyway. Hot or cold will vary, very little.
Also you can give it a shot of ether and see if it pops or starts. This will tell you if it's fuel or something else.
Also you might take it to the top of a very big hill and try and push start it instead of pulling your arm off.
Old Feb 13, 2011 | 11:45 PM
sclark's Avatar
i did the compression test even tho my adpter (mine adpter is shorter then the spark plug for reach that is) dont reach down there it was reading about 30 psi...... i did have some poping noise and it backfire once but nothing after that
i was reading somewhere with it not reaching it will get a fase reading ( my adpter not reaching like the spark plug does)
Old Feb 13, 2011 | 11:48 PM
sclark's Avatar
i was also thinking maybe cam timing is off? i havent check that yet
Old Feb 13, 2011 | 11:50 PM
sclark's Avatar
i have a bad feeling its got low compression damn i hope not if so well then...
Old Feb 14, 2011 | 12:21 AM
GOT BOOST!
If you got 30 psi and you had a screw in compression tester that is good.....your done. It won't even light at 30 psi. You have found your problem.
Take it apart and see what's up.
Old Feb 14, 2011 | 12:25 AM
sclark's Avatar
ok i guess i could have a stuck value but most likey bad rings damn
Old Feb 14, 2011 | 12:28 AM
sclark's Avatar
or maybe even a stuck ring but i doubt it will be that easy damnnnn what does it cost for a head and piston, rings now a days? is it even worth repairing it?
what sucks is i dont know how good the rest of the enigne is meaning clutch,etc
Old Feb 14, 2011 | 12:42 AM
GOT BOOST!
I don't know but nothings cheap nowdays as you know!!
One thing you can do to give you an idea what is wrong is do a leakdown.
If you don't know what that is just Google it.
You can make a leakdown tool by using an old sparkplug and an aircompressor with a regulator on it.
Old Feb 14, 2011 | 12:46 AM
sclark's Avatar
i have a hand pump leak down tester i would have to make a adpter for it to fit but been awhile sense i have done engine repair if i recall i have to block off exhaust and intake? and by doing a leak down test what will that show? or how will that help me narrow the problem done? been a long time sense i have play with engines so refreash my memory please
