Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
90cc - free run, won't shut off
Old Feb 14, 2011 | 08:29 AM
jimsimjr's Avatar
Default 90cc - free run, won't shut off
90cc Alpha Sports Kolt - Had it for about 6 years. Never had to do anything but clean carb and adjust brakes. Runs well, but discovered recently that, if throttle is depressed while in neutral, the engine will rev high and cannot be killed with switch, key or even by removing spark plug wire. I think the throttle may be sticking, but has anyone ever heard of engine continuing to run even after it is switched off and plug wire pulled? How is this possible?
Old Feb 14, 2011 | 08:38 AM
LT80's Avatar
LT80 Expert
Heat..Does the motor feel extremely hot when this happens?
Old Feb 14, 2011 | 08:59 AM
jimsimjr's Avatar
Haven't checked but I'm sure it is hot. Also, since this happened (yesterday), I've had to kick start it. Electric start does nothing. It kicks starts easily and runs/idles smoothly, but electric start was working before this problem.
Old Feb 16, 2011 | 11:30 PM
LynnEdwards's Avatar
Electrical Expert
The engine is shut off by removing spark. But you say that even removing the spark plug wire doesn't shut it off. Dieseling is the only thing left. Something is too hot in the combustion chamber that is firing the mixture on compression.
Old Feb 17, 2011 | 09:08 AM
jimsimjr's Avatar
Makes sense. I had thought about that possibility, but I didn't realize it could happen, especially in a small engine. I guess I'll start with changing the oil and making sure engine is clean.
Old Feb 17, 2011 | 09:48 AM
LT80's Avatar
LT80 Expert
Maybe check the pipe also.
Old Feb 17, 2011 | 10:05 AM
jimsimjr's Avatar
Good idea. I definitely will. Thanks.
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
