Help '04 700 Primary Clutch
Old Feb 18, 2011 | 01:48 PM
Johcha's Avatar
Default Help '04 700 Primary Clutch
Hi Guys,
The belt on my primary clutch doesn't climb to the top of the sheave at WOT. Therefore, my speed tops out at only 45 mph. The belt is correct and brand new.
It has been suggested by other posts that there is a "limiter nut" or "jam nut" that sometimes gets backed off that can cause this situation. Below is a link to a diagram of the clutch assembly that showa a nut (#9).
OEM Parts Polaris SPORTSMAN 700 (A04CH68AP/AQ/AU/CU) 2004 DRIVE CLUTCH - A04CH68AP/AQ/AU/CU - Cheap Cycle Parts
Can anyone verify if this is the correct nut and that if I tighten it, my problem may be solved??? Also, do I need any special tool to get at and tighten it and does it need to be torqued to a specific #?
Thanks in advance for your help.
johcha
Old Feb 18, 2011 | 02:33 PM
kcaves's Avatar
thats the nut, u do need special tools to get in there to it, i take em off every clutch i do, its just plastic, doesn't really do anything, i would check the tower where ur buttons are and see if its tight when u slide the sheaves back and fourth
Old Feb 18, 2011 | 11:36 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
What kind of shape are your buttons in?
Old Feb 19, 2011 | 05:32 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i don't think the primary buttons would stop the clutch from opening unless one was real bad or missing causing the sliding sheeve to **** off side ways. imo
Old Feb 19, 2011 | 08:56 AM
kcaves's Avatar
ive seen the towers get so badly worn in certain spots that when u put new buttons in, the clutch won't shift like its supposed too
Old Feb 19, 2011 | 12:21 PM
Johcha's Avatar
kcaves,
It requires a special tool and doesn't really do anything! Very strange.
Please see the following link were it is discussed:
http://forums.atvconnection.com/pola...ml#post2994026
Do you know where I can get the tool?
Old Feb 19, 2011 | 12:22 PM
Johcha's Avatar
Buttons are fine.
Johcha's Avatar
Tower isn't worn.
Old Feb 19, 2011 | 01:17 PM
kcaves's Avatar
the nut itself doesnt need a special tool, but u need the spider removal tool to get to the nut
Old Feb 19, 2011 | 01:28 PM
Johcha's Avatar
You wrote that you take them off the clutches you work on. Does that mean you don't put them back on because they don't do anything??
