Carb or something else?!?!?
2004 700 idles like a kitten but when I get on it(put a load on it), it falls on its face. You can put it in neutral and it revs good, but when getting on it hard or going up hill, it bogs down. Plugged jet? Timing? Plug? Wire?....
Thanks,
David
Thanks,
David
Well, honestly, I rolled it (broke ribs) and put it up. Rode it from shed to garage a couple of times, then we went out riding saturday. After about 2 hours of riding, it happened all at once. Im thinking trash in carb because while jacking with it on the trail, it got a lil better.
No, it hasnt sat for more than a week. Fresh gas also....wondering if when i rolled it, it picked up some trash from tank. Filter was clean tho
Ouch on the rolling! you should def start by cleaning the carburetor sounds like its a little dirty also if you have a service manual for it you should check the float height but your prob sounds more like a dirty carb to me.
take some carb cleaner and spray intake boot between carb and motor,have to take side cover off, if idle changes when you spray it the boot is cracked and suckin air, alot of these bikes do this
There was also a recall on the breather tube that runs from the airbox to the crancase beather on the engine, the original has a filter on it that gets condensation in it and freezes and cracks, making it suck air, the replacement has no fiter, polaris gave me one free for my 03-700, had symtoms like yours
