Hooking all lights to be on when HI switch is on
Old Feb 23, 2011 | 06:03 PM
HaydenS's Avatar
Default Hooking all lights to be on when HI switch is on
I have a 2007 Sportsman 800 twin efi. To me it seems as if my two cat eyes are brighter than the supposed Hi Beam light on the handlebars. Is there a way to hook them to all come on when you hit the HI beam? I did a short search on here and came up with nothing. Anyone do this before?
Old Feb 23, 2011 | 06:25 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
quadovator has a kit to make them all on at once. i do remember somewhere on here there a few post about the 3 way head light.
Old Feb 23, 2011 | 11:33 PM
zeebs's Avatar
I understand what your saying bout the low beams being brighter than the hi. Quadovator does make a kit but cost plenty for what you get. Plus I think some parts are cheap (scotch-locks) so I would recommend figuring out how to do it and fix it yourself I will see if I can post some info from another forum Im on as I asked the same question. It is a little more difficult then hooking 2 wires together.
Old Feb 23, 2011 | 11:38 PM
zeebs's Avatar
Here is the conversation I had with a guy on another forum.
These instruction should be for a 2008 sportsman 800 H.O. EFI ask the dealer to be sure a 2007 is the same before you cut into wires
http://www.snowandmud.com/forum/f41/sportsman-800-high-beam-headlights-33168.html
Old Feb 24, 2011 | 12:04 AM
NoJoke's Avatar
I used the info from switzomatic's post....worked well with my HID's on my 2007 X2. I would go with a relay instead of the diode setup.
http://forums.atvconnection.com/pola...light-mod.html
Old Feb 24, 2011 | 07:56 AM
HaydenS's Avatar
Thanks guys I'll try the relay method and let you all know how it works out. Much appreciated info here
Old Feb 24, 2011 | 11:56 AM
switzomatic's Avatar
Thanks for adding the link nojoke. I was just about to search my posts for him. Relay mod works better IMO and is much cheaper.
Old Feb 24, 2011 | 01:09 PM
HaydenS's Avatar
Thanks Switzo, I printed the instructions and am pretty handy with mechanical and electrical aspects of most things. I figure this should be a good little project to handle. Much Appreciated
Old Feb 25, 2011 | 06:16 PM
HaydenS's Avatar
I hooked all the wires to the relay and I get the same as it was before. All lights do not come on. Triple checked all the wires stated but nothing =( Must not be the correct wires for the 2007 sportsman 800 or the relay is bad Thanks anyways
Old Feb 25, 2011 | 07:50 PM
NoJoke's Avatar
Do all the stock lights come on and the add on lights won't work?.....or what.
