engine check light
Old Feb 28, 2011 | 09:13 AM
m1782t's Avatar
Default engine check light
I have a 96 forman 400 that the first time you start it after having sat for at least 1/2 hour the oil light doesn't come on when you turn on the key. After you start it you can hear the tappets quiet down so I know I've got pressure. Once I run it a few minutes then you can shut if off and the light works normally until it sits a while again. I have replaced the oil sending unit on the bottome of the engine and checked the wiring as best I could. Any suggestions before buying the expensive control unit?thanks.
SOLOLUCKY
Oct 4, 2024 09:09 PM
Dabears1983
Jun 16, 2015 12:17 PM
Trxoutlawz
Mar 2, 2001 09:33 AM
in2atvn
Sep 20, 2000 04:58 AM
JRM
Nov 19, 1999 01:41 PM
