06 predator 500 bogging down
Old Feb 28, 2011 | 10:33 AM
Jared Roach's Avatar
Default 06 predator 500 bogging down
I changed the oil, oil filter, added K&N air filter, a NGK Iridium spark plug and 93 octane fuel. When you give it full throttle, it boggs down. I cant figure out why, its never acted like before.
Please advise
Thanks
Old Feb 28, 2011 | 10:39 AM
ocala500's Avatar
is the airbox lid back on?
was talking about same thing yesterday to a friend, said sometimes if the airbox is not closed back up properly it can do that.
Old Feb 28, 2011 | 11:02 AM
yes, the box is back together correctly. do you think maybe its the 93 octane? or maybe its running lean because of the increase in air and i havent jetted the motor?
ocala500's Avatar
Also, I have had to do some adjusting to the throttle adjustment on the throttle cable on the handlebars. I know it was atleast stalling out, can't remember if it was bogging at higher RPM's as well.
Old Feb 28, 2011 | 11:21 AM
how do you adjust the cable?
Old Feb 28, 2011 | 12:04 PM
ocala500's Avatar
about 6" from the throttle, there is a rubber boot around the adjustment (mine didn't have the boot around it) either turn it clockwise or counter clockwise. I have seen mention of it many times, could probably search a bit more, if you can't fine tune it by just manually adjusting it.
Old Feb 28, 2011 | 12:09 PM
great! do you know how many ft lbs you are supposed to torque the spark plug?
Old Feb 28, 2011 | 12:22 PM
ocala500's Avatar
i can tell you tonight when i get home and pull open the book, but again, mine is a polaris sportsman 500 2002, so that may be different
Old Feb 28, 2011 | 12:26 PM
maybe so, i can try to do an online search as well
Old Feb 28, 2011 | 05:41 PM
kcaves's Avatar
carb prolly needs adjusted, take out the carb, remove the slide and move the e- clip down one notch and also check ur fuel screw on the bottom of the carb, may have to drill out brass plug, make sure it's 2.5 turns out
