87 Trx 125
Old Feb 28, 2011 | 12:29 PM
blacksheep1875's Avatar
Default 87 Trx 125
I have an 87 TRX 125 (wifes) that is tore down for a rebuild.(top end is trash) I am looking for info that someone has done an easy motor retrofit that has some more umppphhh! The 125 just doesn't get it. I am not looking to chop or modify the frame. Don't care about the reverse or electric start. I looked thru my piles of ATC 185/200 stuff and that will not interchange. I realize that one can only do so much with with a 4 stroke 125 so I hope to find someone that may have done an easy motor swap with a CL or SL or other motor.
Old Jun 7, 2011 | 06:24 PM
ATV Connection Reporter's Avatar
Your question has been selected by the editors for our Ask the Editor column!
Originally Posted by atv connection
First the bad news- we contacted every Honda specialist in our proverbial Rolodex and came up with absolutely no one who has successfully managed to perform the engine swap you have in mind. In fact, without extensive modifications to the frame, the only swaps that we could confirm were those that actually dumped the rightful TRX engine (which had been damaged beyond repair) with the older Honda ATC 125m mill (resulting in even less power).
To read the rest of the response, click here!
Thank you for submitting your question.
Old Sep 8, 2012 | 08:21 PM
fuel6092's Avatar
Default 1987 trx 125
Hey Blacksheep, would you sell the cdi unit from the 1987 trx 125?
