2001 Polaris Magnum
Old Feb 28, 2011 | 04:41 PM
rjzemcik's Avatar
Default 2001 Polaris Magnum
I have a problem with the exhaust side valve cover it fell off for no appearent reason tried to put back on but will only finger tight then it falls back out when a wrench is apply is this a common problem? and what do I do to fix it? need it for plowing.
Old May 10, 2011 | 06:01 PM
ATV Connection Reporter's Avatar
Your question has been selected by the editors for our Ask the Editor column!
Originally Posted by atvconnection
It could be a few things, not the least of which could be a valve cover gasket that has worn to the point where it doesn’t offer proper width between the bolts and threads. You may want to start by popping off the current gasket and taking it to your local Polaris dealer so they can measure how much wear you’ve experienced compared to factory spec.
To read the rest of the response, click here!
Thank you for submitting your question.
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
