400ex Car Wheels/Tires??
Old Mar 9, 2011 | 06:15 PM
sseymour32's Avatar
Default 400ex Car Wheels/Tires??
So I just got my 400ex not too long ago and I just put $600 worth of new wheels and tires on it. Well I have it lisenced and legalized to ride ON-ROAD but I don't wanna burn up my new tires driving on pavement. I also don't want to spend $500-$600 on new tires for street use. If I have a set of 14" wheels and tires with the same 4-bolt pattern, is it OK to use those on my quad? Will it harm anything??
Looking for any input anyone may have. I really want to be able to ride back and forth to work on my quad and save some money on fuel this summer.
Old Mar 9, 2011 | 06:38 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
I'd be equally worried about the suspension- a 400 ex is not tuned to be ridden on blacktop at extended periods.
I think you'd be fine with the 14" wheels- but they may be a bit squirrely on the tar without a damper and better shocks. I'm not even sure I understand the question
You bought new "off road" tires that you don't want to use "on road"- so you're looking to put "on road" tires on another set of 14" rims??? Either way you're buying a new set of rims & tires. You'll need a touring tire for road use.
Old Mar 9, 2011 | 06:59 PM
sdm111's Avatar
2 strokes or 4
Big tires are not good for a quad the center of qravity is too high. And the suspension is not setup for that. Get a set of scorchers don't know who they are made by, ten inch rims 18in. tires plus the fronts. +3 a-arms lowering kit. No need for an extended swinger. Lower the rear by the spring locknut ( no Need to revalve ) and you're set. And when they're setup right look bada@$
Old Mar 9, 2011 | 07:14 PM
sseymour32's Avatar
Thanks for responding.
Ill take both answers into consideration.
To clarify for "beergut": I already have a set of wheels and tires of an old corolla I was going to use. I don't want end up buying more new wheels and tires. Perhaps ill just stick to off-road. DAMN!
Old Mar 9, 2011 | 07:26 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Not only would they be too tall, they would be a lot heavier than atv tires and wheels.
Old Mar 9, 2011 | 08:13 PM
sdm111's Avatar
2 strokes or 4
I personally believe you're setting youself up for a trip to the hosp. sorry jusy keeping it real. Save the money and do it the right way you'll be thankful later.
Old Mar 9, 2011 | 08:26 PM
sseymour32's Avatar
I mean ill Just stick to off-road riding with my quad. Not using my off-road tires. I found the "scorchers" you were speaking of sdm111. They look like a decent way to go as well. Explain What you were sayin I would have to tweak if I went that route?
Old Mar 9, 2011 | 10:46 PM
sdm111's Avatar
2 strokes or 4
+ 2 or 3 a-arms ( the wider the better ) a lowering kit for the front, preferably a +4 rear axle and lower the rear by unscrewing the rear shock spring top perch thing. Trying to widen and lower it to hug the road.
Old Mar 10, 2011 | 06:29 AM
Kerbbirds's Avatar
put the corrolla tires on it and try it
Old Mar 10, 2011 | 07:18 AM
scootergptx's Avatar
Supersock
Hired Gun!
For all the time and money, just buy a used riding lawn mower and tweak it out. At least you won't have to worry about any damage you might be doing to the 400's suspension.
