oil filter cross ref.
Old Mar 11, 2011 | 07:15 AM
bodon's Avatar
Default oil filter cross ref.
I've got a 2011 xp 850.Anyone know of a cross ref.#for the oil filter?Polaris gets too much for thiers.Probably a filter for a small car engine available at Wallyworld for $4.
Old Mar 11, 2011 | 07:32 AM
JCDEYO25's Avatar
I don't have the # for your machine but I'd suggest the Purolator Pure ONE filter...I'm sure you'll get other suggestions but Purolator is an excellent filter....I've uised them for years in my machine...PL14610 is the one I use but not sure about yours...
John
Old Mar 11, 2011 | 08:45 AM
TLC's Avatar
TLC
When I went to aftermarket filters I brought my old filter into the auto store and they matched it up, all that matters is if the rubber seal is the same diameter and has the same size center tread to spin it on the motor.
Old Mar 11, 2011 | 09:34 AM
JCDEYO25's Avatar
Just to add to TLC's post, Make sure the end that screws on is concave and not convex...I don't think the Napa Gold works because it's convex...It won't seat properly.....This info is for slightly older machines, not sure if the XP's are different...
John
Old Mar 11, 2011 | 09:41 AM
TLC's Avatar
TLC
I forgot they did mention the concave vs convex was important also.
I know the 700s and 800 can use a Napa Oil Filter #1357 and Super Tech ST7317 at Wallmart.
Does the 700, 800 and 850 share the same Polaris filter?
Old Mar 11, 2011 | 10:33 AM
JCDEYO25's Avatar
They have different part #'s but I know a member on a different forum that thinks they will still be interchangeable...But not 100% sure...
John
Old Mar 11, 2011 | 12:58 PM
Kerbbirds's Avatar
the filter for the 500 interchanges with the 850 wix number 51358
Old Mar 13, 2011 | 06:43 PM
NoJoke's Avatar
TLC.......What about the anti-drain valve........that should matter too. I don't think all filters have the anti-drain valve feature........??......NoJoke
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Jackg17
Sep 26, 2015 09:30 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
