Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
yamoto 150
Old Mar 14, 2011 | 05:23 AM
suitelife's Avatar
Default yamoto 150
I bought my son a yamoto 150 several years ago (05). Up until just recently it ran just fine. I made the mistake of leaving fuel in the carb over the Florida winter. There was some varnish in the carb when I took it apart. I completely took the carb apart and cleaned it with carb cleaner. I got it to run for a little bit and now the only way it will run is if I spray starting fluid in the throttle body. It has a manual choke but that doesnt seem to work. From what I've read the elecetic chokes arent any better. The float bowl is full of fuel. I can tell because when you remove the bowl screw the new fuel runs out. Any ideas of why fuel isn't being sprayed into the combustion chamber?
Old Mar 14, 2011 | 03:41 PM
Jaster94's Avatar
i know you said you've cleaned the carb, i presume you pulled the jets. the little orifices you see, and the main one, axially down the center/throat of the jets, need to be clean where you can see daylight through them.
i hate to say it, but sometimes you have to clean it more than once to get it running nicely. make sure the petcock valve and the fuel lines to the carb ain't gunked up. i know you said the float has fuel in it, but if the tank to carb delivery system is partially plugged, it may not keep up with what the float is demanding to retain a level. point to ponder and consider....
Old Mar 17, 2011 | 06:48 AM
suitelife's Avatar
Thanks Jaster94,
I'll triple check the jets again. I have full flow of fuel to the carb. the vent in the gas cap is clear also. I'm gonna pull it apart again this morning and see how the fuel is suppose to flow at idle and then acceleration.
I've rebuilt hundreds of car carbs and dozens of small engine (lawn mower, weed eaters etc...) but this is my first atv.
kbazzy
Sep 26, 2015 11:26 AM
JakesDad
Dec 29, 2004 07:21 PM
RacewayATV
Nov 17, 2004 11:58 PM
