gas heated too much?
Old Mar 14, 2011 | 01:44 PM
rajala's Avatar
Default gas heated too much?
Hello,
i have 2005 polaris sporsman 800 twin efi.
it seems like gas heated too much or something...
if i go to drive forrest after 1hour engine wont run any more and gas smels alot. And when i put my fingers in the gas tank gas feel pretty warm...
i tought that if gas is too hot it start to boil in injection system?
after gas is cold or if i fil tank with new gas its runs ok agen.
anyone have similar problems?
Sorry bad english....(Finnish)
and thanks everybody
Old Mar 14, 2011 | 02:27 PM
JCDEYO25's Avatar
Sounds like possibly your fuel pump is on it's way out...
John
Old Mar 14, 2011 | 04:33 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check the vent lines to make sure ther not blocked or pinched off?
Old Mar 14, 2011 | 06:34 PM
Kerbbirds's Avatar
my old 700 would do that, it was a carb model, I wrapped the fuel line to the carb with reflective heat tape , bought it at home depo solved the problem, might try it
Old Mar 14, 2011 | 10:38 PM
Doctorturbo's Avatar
GOT BOOST!
IMHO it would be a real long shot to heat gasoline enough to boil it. The pressures are way higher with an EFI than with a carb.
With a carb it can happen because the gas is at a much lower pressure in the line and is just sitting there in the bowl.
Vapor lock would be the last place I would go with an EFI. A bad fuel pump would be at the top.
Old Mar 14, 2011 | 11:28 PM
rajala's Avatar
Thanks everyone i order new fuel pumb and try after that. I tell later do it help or not -Pete-
Old Mar 15, 2011 | 06:42 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
a fuel bump that is going bad usually will act up when it does get warm and once cooled back down it runs better so it might indeed be a pump. good luck and let us know.
Old Mar 15, 2011 | 07:23 AM
JCDEYO25's Avatar
I hope you are getting an after market fuel pump....Much better idea than having Polaris tell you that you have to buy the whole tank assembly...
John
Old Mar 15, 2011 | 10:26 AM
rajala's Avatar
WOW.. it was guide expensive in finland.... 599 euros.
Anyone have an idea where i can order aftermarket pumb whitc is good.
thanks -Pete-
Old Mar 15, 2011 | 12:16 PM
JCDEYO25's Avatar
Sten,
Please confirm this...
Search: E8198 | Fuel Pump | AutoZone.com
Search: FS111 | Fuel Pump Strainer | AutoZone.com
John
