04' polaris sportsman 600 wont start
Old Mar 19, 2011 | 05:26 PM
twiztidpod's Avatar
Default 04' polaris sportsman 600 wont start
I went out today to ride the polaris around a little. Wouldn't start. I checked fuel, 3/4 tank. I pulled a spark plug out (new plugs 2 weeks ago)
connected the plug back into the plug boot and grounded the plug onto the engine while cranking it, no spark !!! havent had to do too much work on the polaris, but is there any common problems for this with the polaris. I guess it could be the coil, stator, cdi box, any other ideas?? I just dont know where to start. and yes, the run switch was on, lol, I did the same routine I do everytime I start it. Thanks in advance.
Dennis.
Old Mar 19, 2011 | 06:36 PM
Kerbbirds's Avatar
try 2 new plugs , once you gas foul them they wont fire
Old Mar 19, 2011 | 09:14 PM
twiztidpod's Avatar
ok, tried new spark plugs. Not the problem. I could have sworn that I seen 1 spark from the plug, I kept trying and never seen it again. Anyway, I took off the front rack and removed the "cowl" to access the ignition coil. I looked at it and kind of shook the wires around, but dont know what to do with it. lmao. How do I test it ?? not too much on troubleshooting electrical, but i can follow directions and am alway's willing to learn.
Old Mar 19, 2011 | 10:17 PM
Jmuddin284's Avatar
does the battery have atleast 12 volts?
Old Mar 19, 2011 | 10:47 PM
awsume800efi's Avatar
sounds like a stator problem to me the 2002 -2004.5 is known for the stator to go out if i remember they have an updated one that takes a little work to install i think it costs around 500 bucks for the replacement
Old Mar 20, 2011 | 05:28 AM
twiztidpod's Avatar
Wow, dont tell me $500.00 for a stator. I knew they were high but geez. I was thinking along those lines myself but now I hope it is something other than the stator
Old Mar 20, 2011 | 07:12 AM
Kerbbirds's Avatar
yeah there is a kit,, and it is pricey, opt can tell you whats involved
Old Mar 20, 2011 | 10:41 AM
yea those are big hits i know that happened to my 02 700
Old Mar 20, 2011 | 10:42 AM
and good luck i hope its something else too
Old Mar 20, 2011 | 02:49 PM
twiztidpod's Avatar
Thanks guy's, when I get it figured out I'll post back and let you know the damage !!
